need some suggestion
Old   August 4, 2005, 06:18
Default need some suggestion
nabeel mohsin
hi i am doing internal flow through of intake of turbocharge engine of 0.6 mach speed to calculate force on wall at bend.i am using coupled solver with 1 CFL no and inviscid flow.the soltion is not converging at high spped flow .can anybody tell me what i should do nabeel
Old   August 4, 2005, 08:11
Default Re: need some suggestion
edi ghirardi
At first sight: decrease your CFL (at least at startup). By the way: is the solver explicit or implicit?
Cheers
Edi.
Old   August 9, 2005, 19:12
Laika
why inviscid flow for an internal calculation? Why coupled solver? Did the segregated solver mess up?
anyway, good luck,
Laika, still orbiting
Old   August 10, 2005, 03:39
nabeel mohsin
hi, coupled solver is used because seed is 180m/s and implict is being used i reduced CFL 0.001 to 1 but not converged second question answer flow is high speed so inviscid is used and 1 equation model is preferred. my target is to calaculate the pressure force on a area at bend of turbo jet waiting for your response
Old   August 10, 2005, 19:02
Laika
Have you tried to simulate using the segregated solver and a high Re turbulence model yet?
Old   August 18, 2005, 04:55
nabeel
hi i have used segregated solver but with momentum power law solution controls and simplec pressure velocity coupling but not have good result i used 1 equation because of high speed flow any suggestion nabeel
Old   August 22, 2005, 07:55
nabeel
hi i have tried pressure far field but no avail i vannot attain velovity more that 100m/s even map meshing .can any boddddddddy help !!!!!!!!!!!!!!!!!! nabeel
Old   August 23, 2005, 05:45
not solved yet
hi i have tried skw turbuolence model but it was not diveging and with SA model it was converged till 100 m/s any helppppppppppp nabeel
suggestion for thermophysicalproperties for high temperature buoyant flow braennstroem OpenFOAM Running, Solving & CFD 0 March 21, 2011 15:06
any suggestion about method to use? cnmm Main CFD Forum 0 May 29, 2009 00:13
Suggestion to make spray simulations more stable fabianpk OpenFOAM 4 October 16, 2007 07:53
To webmaster or forum modulator: a suggestion ma Main CFD Forum 16 December 11, 2004 11:56
can you give me some suggestion? reck Main CFD Forum 0 November 25, 2001 01:40
