Compressible, turbulent flow in a pressure tube |
August 4, 2005, 05:23 |
Dear all,
I am trying to compute air flow through a total-pressure tube with the segregated solver. The flow is compressible (ideal gas law) at Ma=0.26 and turbulent (standard k-e). I am using velocity-inlet and pressure-outlet as boundary conditions. I have set the operating pressure to zero. Unfortunately I cannot get the solution converged. Either I get a divergence detected in pressure correction or the residuals are oszillating. Any suggestions are highly appreciated! |
August 5, 2005, 09:21 |
Re: Compressible, turbulent flow in a pressure tub
for the second question, you should adjust your grid. hope any help.
August 9, 2005, 02:47 |
Mario,
You cannot use a velocity inlet boundary condition with a compressible fluid. You need to use either mass flow inlet or pressure inlet. If you know the inlet velocity, you can calculate the inlet mass flow ok. |
Outlet pressure for compressible flow | Michelle | CFX | 12 | September 1, 2015 19:38 |
solver for subsonic compressible turbulent flow in OF 1.7 | nileshjrane | OpenFOAM Running, Solving & CFD | 20 | February 13, 2012 06:54 |
compressible steady/transient turbulent flow | orlikev | OpenFOAM Running, Solving & CFD | 1 | November 1, 2010 08:16 |
pressure distribution in water flow, differences in icoFoam and COMSOL | deniggo | OpenFOAM Running, Solving & CFD | 14 | September 30, 2010 04:48 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
