Please help.BC for centrifugal impeller
Old   August 4, 2005, 03:36
Default Please help.BC for centrifugal impeller
Shiju G.Thomas
sir,
I am modeling a centrifugal fan impeller. I know the experimental results for suction pressure, discharge pressure and mass flow rates. What inlet and outlet conditions should i specify....Please help
Old   August 9, 2005, 19:09
Default Re: Please help.BC for centrifugal impeller
Laika
if you give somewhat more info on the setup and the available flow conditions, we probably can help you with this.
kind regards, Laika, still orbiting
Old   August 10, 2005, 00:24
Shiju G.Thomas
Thanks for the response.... I have modelled an impeller with axial in flow and radial out flow. It is used to suck air to a unit. I have the experimental values for mass flow rate , inlet pressure and outlet pressure.
Old   August 10, 2005, 19:00
Laika
I'd apply a mass flow inlet and a pressure outlet.
If you can calculate the inlet toal pressure, I'd do a pressure inlet -- pressure outlet simulation as well, to see if the calculated flow rate matches experiments.
good luck,
Old   August 11, 2005, 06:27
Shiju G.Thomas
Thanks very much... By inlet total pressure u mean suction head+ dynamic head ?
Having a few problems in simulating a rotating impeller ajinsan CFX 12 February 4, 2016 17:10
Volute outlet flow into impeller inlet Anthony_impeller CFX 4 December 13, 2011 17:17
Simulation of an Axial Impeller cnchilavert CFX 1 October 15, 2011 03:01
[GAMBIT] influence between angle in impeller blade and centrifugal pump performance barak182 ANSYS Meshing & Geometry 2 August 18, 2010 04:07
tascflow - impeller volute interface abaqus CFX 0 August 21, 2003 14:06
