Flow over a Circular Cylinder
Like Tree1Likes
Old   July 6, 2010, 17:34
karine
thecfduser is on a distinguished road
If u are looking for the mean values, u must of course use a turbulence model.
Anyway, it is why we invented turbulence models.
U does not need to refine the mech very much....Only near the solid boundaries if u want to use a low-Re model, or a 2 layer model....
I dont know if a URANS model will be able to capture a non-stationnary flow....but i think no.
We cannot use a DNS for such a flow, unleast u can wait a mont to get a solution
Remember that for such a Re, even in experiences u will not see a vortex schedding (u have it, but u have a lot of other scale eddies...)
thecfduser is offline   Reply With Quote
Old   July 7, 2010, 07:41
Question Flow over a circular cylinder
  #22
maa
Mary
maa is on a distinguished road
I need to repeat the simulations because I īll work for another Reynolds and I need to know if the results are or not correct.
1- I think that the simulation is converged because I have 20 time step and during the simulation the fluent use only 11 time step to converge.
2- I have done one simulation for RNG steady and the result has the same of the unsteady.
3- In literature they used 2D.
4- I donīt have low-Re modification because Iīm using the FLUENT 6.3 and I donīt have that option.
Why shouldnīt I use a turbulence model for Re = 27 000?
maa is offline   Reply With Quote
Old   July 8, 2010, 02:58
karine
1-Monitor variables. Residuals are not sufficent to judge convergence. Anyway, in my life, i never used more than 2 iterations per time step.... Refine ure time step instead of using 11 iterations by step. if ure time step is dt, u will only resolve correctly the scales wich lifetime is higher than dt/2.
2-Yes because RNG as k-epsilon model is a bit...lets say robust.
In fact, RANS models are models that take average.
In average, u have 50% probability that the first big eddie comes from the top, and 50% that it comes from the down of the cyclinder. So a RANS model wil not give u a vortex schedding because it is doing averages (unleast the model is not highly diffusive, so it will be the NUMERICAL residuals that makes ure vortex schedding start).
3-OK. They are supposing a very long cylinder and uses RANS models (DNS or LES will need 3D, even if the average mean flow is 2D)
4-U have it, but it is for professional so it can only be activated by typing a command line. Anyway, for RNG u still have it in the interface: differentiel viscosity option. U must year a very fine near wall mesh.
U can use an intermediate near wall resolution, wich is the enhanced treatement in FLUENT.
So, to know wich model using, compare with litterature. Find the best model, that u can use it for the rest of ure simulations.
Verify that solution is independant of the grid.
Use steady RANS if the simulation still converging (monitor variables and not only residuals)
An important thing, do a good grid quality. Gambit does not handle body fitted grid and this is a big limitation....
Old   August 24, 2010, 03:44
Default flow over cylinder
  #24
Dr.Sharad Pachpute
pachputesharad is on a distinguished road
I modeled 2-D flow over cylinder .ICEMCFD used for grid generation with O-grid.Computational domain like 10d upstream,20d top and bottom,20d downstream.Used BC such that inlet-velocity inlet,oulet-outflow,Top,bottom-symmetry.Firstly for Re=100 with dt=0.01,t=20.compared this Cd=1.31+-0.02 value with research paper data
pachputesharad is offline   Reply With Quote
Old   April 21, 2011, 05:36
Default Vortex Shedding
  #25
Rishikesh
rishi_iyengar is on a distinguished road
Hi Sanjay
I think the accuracy of capturing vortex shedding is more fundamentally based on the grid that you use.Use a very fine grid in the wake region.Try and control the y+ value also.
I think if you can do this you ca capture vortex shedding with any turbulence model.
Rishikesh
rishi_iyengar is offline   Reply With Quote
Old   April 22, 2011, 03:14
Question Something odd in inviscid simulation
  #26
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Hi all,
I have done the simulation of inviscid flow in circular cylinder (i just follow the step of http://www.et.byu.edu/~maynesrd/clas...20Cylinder.pdf). I think some thing odd there. I find wake behind the cylinder. How it can be?? In my mind, inviscid flow will not give wake. Is any body can explain the reason??
Thank you
Teguh Hady Ariwibowo
Now Or Never!!!
teguhtf is offline   Reply With Quote
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 18:51
Which Solver/Model to use for flow over Circular Cylinder ? Re [1 , 10^6] WolfgangS. OpenFOAM Running, Solving & CFD 1 December 6, 2010 03:48
3D FLOW OVER A CIRCULAR CYLINDER Srinivas Mettu FLUENT 2 April 4, 2010 23:11
flow past a circular cylinder Senthilkumar Main CFD Forum 2 April 20, 2009 00:18
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
