CONDUCTION+CONVECTION
Old   August 2, 2005, 06:35
Default CONDUCTION+CONVECTION
ranton
I have a conjugate heat transfer problem. One channel (a fluid) in contact with a plate (a solid, not the thin wall model but a plate with its thickness). In the interface I have a wall and a wall-shadow, because of the coupling between conduction and convection. In the other side of the solid, a constant heat flux condition. In the fluid side the boundary condition is velocity inlet and pressure outlet and symmetry.
However it seems that the heat does not arrive to the fluid. I have tried several meshes of the wall thickness of the plate and of the fluid domain. And it seems that the heat does not arrive to the fluid (air) and thus there is a heat imbalance (report/fluxes/heat transfer energy) in the whole domain.
What am I doing wrong?? Thanks!
Heat conduction and convection simulation debashis OpenFOAM Running, Solving & CFD 5 March 24, 2014 00:28
heat conduction in solid and convection in flow kunal FLUENT 3 February 29, 2012 05:42
Convection with Shell Conduction Corentin FLUENT 7 January 30, 2012 14:12
Convection & conduction simulation problem debashis FLUENT 1 June 26, 2009 04:45
Conduction and Convection Radhika Siemens 2 November 30, 2006 16:06
