UDF using data from postprocessing surface
Old   July 31, 2005, 13:58
Default UDF using data from postprocessing surface
Cedric
Hi
I'm trying to create a UDF where I need to get the pressure average from a post processing surface. How can I get this data? how can I get the cell index of the cells that my postprocessing surface crosses?
Many thanks
Cedric
Old   August 1, 2005, 05:21
Default Re: UDF using data from postprocessing surface
Joey
Could you discribe your case more detailedly? So, maybe I could give some useful information to you.
Old   August 1, 2005, 12:16
Cedric
yes,
I have a pressure outlet.I'm forcing this pressure outlet with a UDF (thanks to "DEFINE PROFILE"). The pressure at this outlet as to follow a certain equation: it has to be the same than the pressure on a certain point that is in the middle of my computation domain. I have defined this point in surface>point in Fluent. What i need to do is to get the pressure at the cell where this point is situated and to use it in my pressure outlet UDF. I know that the fonction C_P(c,t) can give you the pressure if you know the cell index "c" and the thread "t". So, what I think is that if I have the cell index, then, I should have solved my problem. Can you help me on this?
many thanks cedric
fluent udf, saving data in udf mohsen zendehbad Fluent UDF and Scheme Programming 15 June 14, 2017 00:23
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
Use of Experimental Data in fluent using UDF anvitaa.sharma FLUENT 2 February 18, 2010 11:46
Data logging in UDF carno FLUENT 2 October 6, 2008 02:43
Postprocessing Pressure data spanwise over a wing Rick FLUENT 1 February 3, 2006 10:28
