display steamlines in the thin wall
Old   July 29, 2005, 17:41
Default display steamlines in the thin wall
Ridha
Hi heat transfer in a tube heat exchanger (in 3D) have been modelised. in Fluent i define a thin wall BC (turn on the shell conduction option in the wall boundary condition panel, define the thikness, mterial). after some iterate. i want to display the temperature and the streamlines on the fluid and the wall but only the tempearture on the fluid i can seen
how display the streamlines in the wall Thank s
Old   August 3, 2005, 10:13
Default Re: display steamlines in the thin wall
Swarup
Well, how will you see streamlines "in" the wall when you cannot pass fluid through it?
Old   August 3, 2005, 17:26
ridha
i will see the isocontours of the temperature et not the streamlines in the wall , think you
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
Influece of wall velocity in the main flow marvin CFX 0 March 22, 2008 03:05
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 05:29
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 02:16
