July 29, 2005, 07:47 |
Flow over a flat plate: BCs
Hi What kind of boundary conditions should i use if i would simulate the flow around a palette placed on a flat plate? The domain is a rectangular box which has the bottom face as wall and on this there's the palette; the front face is set as velocity inlet and the side faces are periodic. I have trouble in setting the top and exit boundary conditions because the only ones that really works are: velocity inlet on top (Is it physical?) and outflow at the exit face. I would like to know if there are more physical BCs that easily converge. Thank you
July 30, 2005, 07:48 |
Re: Flow over a flat plate: BCs
Dear Sbafinni:
This link is developed specially for flate plate boundary layer using fluent: http://energy.bradley.edu/ME521/Tutorialflatplate.pdf Best Regards Mehdi Ghoddosy |
July 30, 2005, 08:55 |
Thank you for your help, it was real helpful for a lot of details but maybe i've made some mistakes in describing my problem (probably due to my bad english): i've already done the run of a free boundary layer over a flat plate in 3D with the boundary conditions described in the tutorial. Now i've inserted a micro vortex generator in the boundary layer so the pressure outlet condition at the outlet is no more physical and even if i try to use it, the run doesn't converge with any combination of boundary conditions (top-exit). Now, the best one should be outflow at the exit and pressure outlet on the top of the domain but it doesn't works; the only way to let it works is to change the top condition in velocity inlet but i think it is not physical. What i think is that Fluent doesn't likes to work with the pressure on the boundaries because it's not able to adjust the little variations that occur in the pressure distribution at the faces...so i would like to know if there are some tricks or tips to force it to work with the right boundary conditions. Thank you
April 16, 2010, 05:58 |
Rep Power: 17 |
Hello!
Actually this topic was posted long time ago but It is still useful for me! But unfortunately, I can not download the tutorial by this link! Can you help me? thanks! |
November 1, 2010, 01:52 |
Urgent
Reyhaneh Sadat Ghazanfari
Rep Power: 16 |
Dear Mehdi
I'm a master student of hydraulic structures in ut and my thesis is 3d modelling of flow in channel using fluent.I find you really experinced in this field.would you please give me your e-mail to contact you? best regards Reyhaneh |
October 24, 2012, 15:54 |
nadesan
Rep Power: 14 |
I am encountering the same problem. The free stream boundary condition at the top (velocity inlet) is fine unless and until you are sure that the disturbance from the wall gets dissipated before reaching the top wall, else you would force the disturbance to subside by using the dirichlet boundary condition at the top. I am getting confused to specify the boundary condition. I cant download the pdf file. Could you please help me in getting the pdf file?. My mail id is tk7305@gmail.com
Thank you so much Rgds thiru |
Boundary Layer of Laminar Flow over a Flat Plate | Blasius_Pohlhausen_Crocco | Main CFD Forum | 12 | September 30, 2013 18:35 |
supersonic flow over a flat plate | Vishwajeet | Main CFD Forum | 1 | April 15, 2007 23:00 |
results for flow past flat plate normal to flow | lisa | Main CFD Forum | 2 | August 30, 2005 17:36 |
Flow passing a porous plate. | Hao Yu | Main CFD Forum | 2 | October 19, 2000 02:52 |
Supersonic flow over flat plate - best model | Chris Rand | FLUENT | 4 | October 3, 2000 07:58 |
