Collect data at every 10 time steps, npt each.
Old   July 29, 2005, 02:50
Default Collect data at every 10 time steps, npt each.
Anindya
How can I collect data (data sampling for unsteady statistics) at say every 10 time steps in unsteady calculation (LES) to find the mean values of velocities, pressures, etc, intead of every time step in fluent?
Thanks
Anindya
Old   July 30, 2005, 08:10
Default Re: Collect data at every 10 time steps, npt each.
Mehdi Ghoddosy
Dear Anindya:
Do you want to sample data is specfic points, every 10 time step?
Best Regards
Mehdi Ghoddosy
Old   July 31, 2005, 02:55
Anindya
Hi Mehdi,
I want to sample the data velocity, pressure) along a line to get mean profiles. Also when I get the time averaged data for the whole field, I want to get the average by considering the data every 10 time-steps, instead of each time step. So is it possible to do so?
Thanks for your help.
Anindya
Old   July 31, 2005, 08:09
Mehdi Ghoddosy
Dear Anindya:
YES, it is possible. Fist define the lines in surface>line. THen go to solve>monitor>surface. increase the numbber of monitors and select write and plot every interation. Now, in define page select line and appropiate report type. Now, the data is written to a file and you can choose the iterations for example, in excel. But if recommend to define point along the line in the case of defining line for more control on output points.
Best Regards
Mehdi Ghoddosy
A variable expressing time steps in UDF? lcw FLUENT 6 March 28, 2020 04:07
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 13:32
