unsteady problems
Old   July 29, 2005, 02:25
Default unsteady problems
Baskar
hi in case of unsteady problems how can i see the profiles at some particular time step. eg. in case of combustion problems, i want to see the temperature profile of a particular surface at particular time only. solve-monitor is giving for every time step, can i have a control over it thanks in advance
Old   July 29, 2005, 04:36
Default Re: unsteady problems
CFD-novice
I would save a data file for the particular time step and then use it to display the profile in question.
Saving the data file can be done manually or using the autosave feature.
how to predict unsteady flow from case definition? Felix Main CFD Forum 6 August 28, 2007 17:40
Unsteady Boundary Layer Problem C.J.Yoon Main CFD Forum 0 January 27, 2006 05:19
Getting convergence with unsteady problems Freeman FLUENT 4 December 1, 2005 14:13
Under relaxation factor for unsteady NS scheme? zonexo Main CFD Forum 0 September 26, 2005 22:15
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 12:30
