UDF (write a data file) problem
Old   July 28, 2005, 21:36
Default UDF (write a data file) problem
lichun Dong
Hi, all:
I am modeling a liquid drop movement on a surface and need to calculate the mass of the liquid drop. Therefore, I wrote a UDF, (actually a DEFINE_RW_File Macro) and try to save a data file. The code seemed to work, no any problem was showed during compiling or interpreting, however, I can not see any data file was saved, The mmanual says that once I save a data file, the UDF will work and a data file shoula be saved? Am I right?
Therfore, my question is: How to run a DEFINE_RW_FILE udf? would a data file be saved once the udf works properlly?
Thanks very much for your help and suggestion
Lichun Dong
The followed is my code.
#include "udf.h"
DEFINE_RW_FILE(weight_center, filep)
Domain *d
face_t f;
cell_t c;
Thread *t;
d = Get_Domain(1); /* Get the domian using Fluent utility */
real volume;
real vol_tot = 0;
real position[ND_ND],x,y,z;
real xadjvol = 0;
real yadjvol = 0;
real zadjvol = 0;
real xcenter;
real ycenter;
real zcenter;
real flowt;
real vowater;
/* Loop over all cell threads in the domian */
thread_loop_c(t,d)
/* Loop over all cells */
begin_c_loop(c, t)
volume = C_VOLUME(c,t);
vowater = C_VOF(c, t[1]);
vol_tot =+ volume*vowater;
C_CENTROID(position, c, t);
x = position(0);
y = pisition(1);
z = position(2);
xadjvol = xadjvol + x*vowater*volume;
yadjvol = yadjvol + y*vowater*volume;
zadjvol = zadjvol + z*vowater*volume;
end_c_loop(c,t);
xcenter = xadjvol/vol_tot;
ycenter = yadjvol/vol_tot;
zcenter = zadjvol/vol_tot;
flowt = RP_GET_Real("flow-time");
fprintf(filep, "%d", flowt, "%d", xcenter, "%d", ycenter, "%d", zcenter);
Old   July 29, 2005, 04:16
Default Re: UDF (write a data file) problem
CFD-novice
As I understand the UDF manual, the DEFINE_RW_FILE macro does not by itself write or read any files. It only determines, what additional information is written/read to/from the case or data files that you write/read yourself manually or in a script.
Maybe as you set up a small test model and write the case/data file in clear text (not binary), you can inspect the files to see if your data is written.
I haven't used this macro myself yet though.
Old   July 29, 2005, 12:39
lichun Dong
Thank you for your response. Have you used DEFINE_ON_DEMAND and save data using C_UDMI?
I will be very appreciated if anyone can give me some advice.
Lichun dong
pisoFoam compiling error with OF 1.7.1 on MAC OSX Greg Givogue OpenFOAM Programming & Development 3 March 4, 2011 18:18
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
UDF Getting data from file jreig FLUENT 0 July 10, 2009 09:07
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
