V2F Model
Old   July 28, 2005, 19:13
Default V2F Model
Maged
Hi all
Does anyone knows, how much does the licence for the V2F turbulence model cost?
Regards, Maged
P.S: I am a graduate student and I need this model for the research of my MSc thesis.
Old   July 29, 2005, 07:41
Default Re: V2F Model
dirk
Maybe you can a get free trial first, you should talk with your admin. We got one trial license (also at university) for three weeks, but V2F didn't work in my case.
Old   July 29, 2005, 11:08
Maged
Dear Dirk
Thank you so much for your help. Have you tried to use the V2F model for the Jet-in-crossflow case? (I have read your previous message about "LES of Jet in crossflow") I am also conducting numerical simulation of a Jet-in-crossflow, but I don't have enough computational resources to perform LES, so I will compare the results of different RANS models like standard k-e, SST, RSM and maybe also V2F with experimental results. I am using PC with 3 GB processor and 2 GB of RAM, so I think the use of LES or DES will not be practicable for my case.
Your help and comments are highly appreciated.
Maged
Old   July 29, 2005, 12:09
dirk
That's right, I used it for a JICF. But my duct flow was laminar and so I wanted to simulate separation and transition around the exiting jet. V2F couldn't do this properly, the other turbulence models by the way couldn't either. But I didn't test V2F in fully turbulent flow.
Dirk
Old   July 29, 2005, 19:03
Anindya
I think you can do a les simulation for your case with about 2M cells (max). But it will be a little time consuming.
V2f turbulence model qtian OpenFOAM Running, Solving & CFD 74 January 15, 2018 08:19
V2f model , Fluent's background pablo FLUENT 2 July 11, 2016 17:32
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 06:24
v2f model in Fluent Ramakumar FLUENT 0 August 2, 2007 03:23
V2F turbulence model Mark Render Main CFD Forum 8 February 15, 2001 10:17
