July 28, 2005, 18:09 |
REFERENCE VALUES
Can someone please explain to me what the reference values "area" and "length " is for ? thanks
July 29, 2005, 03:47 |
Re: REFERENCE VALUES
These reference values are not used during calculation, but only for some post-processing tasks. E.g. calculating a drag-coefficient, requires a reference area. Or if you ask Fluent to report on surface heat transfer coefficients, he uses the reference-temperature.
hope this is enough, cheers, Laika, still orbiting |
August 1, 2005, 13:47 |
hi wat lika mentioned is correct if you are interested flow past problems and calculating coefficients like LIFT AND DRAG skin friction...... you should worry about reference area i think for 3D you can get it from projected area option bye
April 18, 2010, 06:53 |
hi
hassan
Rep Power: 17 |
hi sir
i wana calculate surface nuselt number in expansion value can u explain to me what should i used for refrence value temprature velocity area height lenghth .... ,,,, thank u |
December 5, 2019, 16:29 |
#5 | |
Roger Iván
Rep Power: 17 |
https://www.youtube.com/watch?v=V_ozqKflSx8 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
It would be wonderful if a tool for FoamToTecplot is available | luckyluke | OpenFOAM Post-Processing | 165 | November 27, 2012 07:54 |
Building OF 1.6 - CentOS 4.x | Pytthon | OpenFOAM | 1 | February 2, 2010 12:05 |
Reference Values for Air-Foils with high Angle-of-Attack? | hornig | FLUENT | 0 | January 9, 2010 12:11 |
Fluent 2D Reference Values | Adam | FLUENT | 1 | January 16, 2009 03:58 |
