Instantaneous and mean velocity vectors look same
Old   July 26, 2005, 18:51
Default Instantaneous and mean velocity vectors look same
anindya
I am facing this problem for a long time. In transient analysis, I enable data sampling. When I look at the instantaneous and mean velocity vectors, they look exactly the same. This happened in 6.1 and also in 6.2. I have the feeling that the mean velocity vectors are not shown properly and instead it shows the same instantaneous vectors too.
But the instantaneous and mean velocity contours look different as it should be.
Anyone has any idea what is wrong? Is this a bug in fluent? I have run my simulation for a long enough time.
Thanks
Anindya
Old   July 28, 2005, 05:44
Default Re: Instantaneous and mean velocity vectors look s
zxaar
okey, here is the solution to your problem:
go to vector panel, you will see on the left side options for scale factor then skip ,
down here below "vector options" , there is something called custom vectors, open this panel and create the vectors based on the "unsteady statistics"
that is chose x y and z components from unsteady statistics or mean flow data, and then plot it, this is your correct vector plot you need.
Old   July 28, 2005, 19:03
Anindya
Thanks a lot yaar. It works perfectly.
One more question. When I want a mean profile (of say velocity), I use unstaeady statistics panel and then choose mean velocity. right? or do I do something else just like getting the mean vectors?
Sincerely,
Anindya
Old   July 29, 2005, 00:11
zxaar
yes exactly
