doubt on meshing a cylinder
Old   July 22, 2005, 13:55
Default doubt on meshing a cylinder
FELIX JOE S
Sir,
I am a student learning fluent in IIT Chennai. I had a problem in meshing a cylinder of 0.004m(outer diameter) and 0.0037m(inner diameter) [i.e. thickness of 0.0003m ] and a height of 0.02m height. So the problem is that the meshing error(in the Gambit) is occuring .I used all the three basic volume meshes. The error is that " SIGSEGV (segmentation violaton) error" . All occurs for the mesh size of 0.0001 . please suggest me ways to solve it.
thanking you
JOE
Old   July 22, 2005, 14:06
Default EXPLAIN ME ABOUT AN ERROR
MANIVANNAN
Sir,
I am a student learning fluent in IIT Chennai. I had a problem in axis symmetric valve the problem is in fluent which says divergence detected in AMG solver: X momentum the inlet we give as total gauge pressure & outlet is pressure which is 0.
thanking you
Old   July 22, 2005, 14:31
Default Re: EXPLAIN ME ABOUT AN ERROR
AJG
I think u are using to many nodes! the density is to high for your server. Try a more coarse mesh.
Old   July 23, 2005, 01:31
Default Re: doubt on meshing a cylinder
Mahesh
create a cylindet of 4 & 3.7 as dimensions. in Fluent, say grid is created in mm. So it will take new dimensions as 0.004 & 0.0037
Old   July 23, 2005, 03:21
Mehdi Ghoddosy
Dear Felix:
What meshing scheme are you using? I think using Map scheme can help you. However if you decet you meshing scheme i can give you more offers.
Best Regards
Old   July 23, 2005, 06:15
Swarup
Check your problem set-up, especially your boundary condition values. I hope you understand what is meant by divergence. your variable values are going out of bounds. Are you getting some messages before divergence detection message is thrown? Swarup.
Old   July 23, 2005, 12:47
sharuk
use size function
Old   July 25, 2005, 08:36
Default Re:Re: doubt on meshing a cylinder
FELIX JOE S
Sir
I have tried it doing that also but the error is in the mesh of that length to thickness ratio (as i think). The mesh scheme i used predominently was TET/HYBRID still i also used Hex Map. I also modeled it in mm still the same error is present.I still need the mesh size for both i.e. (1) if i model it in same size (2) if in scaled one but i have tried both of it. I still need more advice
Thank you for your valued suggestions
JOE
Old   July 25, 2005, 08:45
FELIX JOE S
Sir
JOE
Old   July 25, 2005, 09:04
Mehdi Ghoddosy
Dear Felix:
I think your mesh and model sizes does not have any problem, and range in conventional geometries. Also, meshing cylenders is a conventional and frequently used case in CFD problems. So, the problem arises in creating geometry or meshing process. To avoid this, first forget your cylinder thickness and try to mesh remaining geometry. Fisrt, grade start and end caps(circles). Split them to four curves and try to mesh the cap surface using Map scheme. Then, grade the cylinder wall, and mesh it using Map scheme. Now, mesh the volume using Map or Cooper scheme. Following this concept no problem should be arised. If you got the error again, there is an error in your program, or concept of defining mesh or geometry. If no problem arised we would discuss about ramainnig part of your model. Good luck.
Best Regards
Mehdi Ghoddosy
Old   July 25, 2005, 09:08
  #11
Mehdi Ghoddosy
Dear Felix:
Excuse me, forgot to say, create the geometry using down-top approach. Means that first create the circles and then wall surface, then compose the volume using these faces.
Old   July 26, 2005, 04:44
  #12
sharuk
this is for manivannan, check ur boundary conditions, and reduce the relaxation factors.if it doesn't work go for coupled/implicit solver.i'm in krishna hostel, room no 111, no. 9884204548, tell me if u got it correct. sharuk
Old   July 27, 2005, 05:06
  #13
zxaar
why don't you try making mesh in mm and then scale it in fluent. if the problem coming from mesh dimensions. otherwise sigmentation violation suggest that there is a problem with your geomtery. check that.
Old   July 27, 2005, 09:06
  #14
Mehdi Ghoddosy
Dear Felix:
Excuse me, if I have not read your message carefully; but as I remember you said that tried to generate the mesh with dimension in mm and got the error again. However, if you have not tried to generate your mesh in mm, I recommend try it first.
Regards Mehdi Ghoddosy
2D planar cylinder meshing problem saisanthoshm88 ANSYS Meshing & Geometry 15 December 27, 2010 12:14
[ICEM] (ICEM CFD) meshing over a cylinder vmlxb6 ANSYS Meshing & Geometry 6 August 11, 2010 15:37
[blockMesh] Meshing inside a cylinder so that the edges contain more cells than the center Bertrand OpenFOAM Meshing & Mesh Conversion 1 April 13, 2010 05:46
Best Meshing scheme for Cylinder Nutrex Main CFD Forum 4 July 29, 2008 12:03
doubt on meshing joe FLUENT 2 September 12, 2005 14:17
