July 19, 2005, 15:37 |
Herschel Bulkley panel
Has anyone ever used Herschel Bulkley panel for viscosity. I have had a problem to select that model under material panel. When i clicked on the drop down list of viscosity model, that model was not available in fluent 6.2. I was wondering if somebody could help me how to select that particular model and put it into as viscosity equation. Thank you in advance
July 20, 2005, 04:50 |
Re: Herschel Bulkley panel
The Hershel Bulkey model is not available if you have already selected a turbulent model.
If you want to use a turbulent model, you need to select before the hershel model and then through the command line to activate the k-e model. HV |
Herschel Bulkley model Problem | emad | FLUENT | 6 | September 12, 2018 14:35 |
Yielding viscosity for Herschel Bulkley model | Godwin | FLUENT | 1 | December 12, 2011 06:42 |
automatization herschel bulkley | hamina | FLUENT | 0 | February 22, 2006 06:44 |
automatization herschel bulkley | hamina | FLUENT | 0 | February 22, 2006 06:41 |
otomatization herschel bulkley into fluent | hamina | FLUENT | 0 | February 21, 2006 11:45 |
