Gambit can be run in parallel?
Old   July 18, 2005, 22:03
Default Gambit can be run in parallel?
zjuADou
My own code need the parallel mesh and I want to achieve it by using gambit. Is it possible? Does gambit have a parallel version which can be used to generate and decompose mesh?
Thanks.
Old   July 24, 2005, 08:33
Default Re: Gambit can be run in parallel?
Mehdi Ghoddosy
Dear zjuADou:
As i know there is not parallel processing possible using GAMBIT. But, you can do it using EXCEED capabilities or using double-processor motherboards
Best Regards Mehdi Ghoddosy
new Solver won't run parallel Chris Lucas OpenFOAM 4 January 10, 2012 11:30
batch mode - parallel run turbotel CFX 2 March 29, 2011 17:53
Parallel Run on dynamically mounted partition braennstroem OpenFOAM Running, Solving & CFD 14 October 5, 2010 15:43
Run in parallel a 2mesh case cosimobianchini OpenFOAM Running, Solving & CFD 2 January 11, 2007 07:33
Minimum number of nodes to run CFX in parallel Rui CFX 3 April 11, 2005 21:46
