Fluent View Factor Exportation
Old   July 18, 2005, 18:05
Default Fluent View Factor Exportation
Scott
I am currently working on an enclosed radiative heat transfer problem with complex geometry. All surfaces in the enclosure have set temperatures and the media is nonparticipating. My sole purpose is to obtain net radiative fluxes to specific surfaces. I am currently using Fluent with S2S radiation model and only solving the energy equation. Is there a way to export the view factors calculated using the S2S model so that I do not need to solve the problem within Fluent? Thanks for any help that anyone can provide! Scott
Old   July 20, 2005, 05:22
Default Re: Fluent View Factor Exportation
Mahesh
you can open that s2s.gz file, take the matrix of view factors and use wherever u want to use. Fluent writes view factor at every node. I m not sure how accurately fluent calculates the view factor. U just draw a simple geom with very only one grid point (i.e. a normal geom, no mesh), do hand calculation & check with Fluent first.
Old   July 25, 2005, 02:38
Scott
I have looked into this, but it is difficult to keep track of the separate faces with a complex geometry where I do not have previous knowledge of the view factors. Thank you for the suggestion though.
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
Comparison of fluent and CFX for turbomachinery Far CFX 52 December 26, 2014 19:11
CFX or Fluent for Turbo machinery ? Far FLUENT 3 May 27, 2011 04:02
grid view in fluent nirupam FLUENT 4 February 16, 2006 01:29
