Fluent on dual processor machine
Old   July 15, 2005, 17:47
Default Fluent on dual processor machine
Razvan
Dear Fluent users.
My problem is of tehnical nature and it might not have any connection with the program itself. I completed today my dual processor machine:
2*Opteron 246 Tyan Tiger K8W 4 GB Corsair PC3200
To be more precise, I bought the 2nd processor. I installed WinXP x86-64 Professional Edition and Fluent 6.2.16 and went to bechmarking. Actually, I have a personal benchmark, a Rotor37 I calculated some time ago, with a 820.000 elements structured mesh.
On single CPU configuration I got 55 seconds/iteration.
Now comes the surprise: on dual CPU, SINGLE process I get 67 seconds/iteration !!! I couldn't belive my eyes! And that's not all: on PARALLEL processes I barely could achieve 40 seconds/iteration after testing several partitioning methods.
For those who don't know Tyan Tiger K8W, it is a SHARED memory board. Could this be the reason for such a poor performance? All reviews I ever read about this mainboard revealed a slight performance drop in comparison with DISTRIBUTED memory boards, but far smaller than what I am experiencing here!
I mention to have a strong background in serial Fluent, so I am pretty sure I made no mistake in setting up the case.
So, what I'm asking you is: have you ever experienced something similar, or even you may have an identic mainboard or a pretty much same configuration and can enlight me about this? Because I am quite desperate thinking that I invested 3000 $ in a machine which is only a "fart" better than a single CPU 1000 $ machine !!!
Appreciate any help.
Razvan.
Old   July 16, 2005, 07:28
Default Re: Fluent on dual processor machine
Jim Clancy
If you use Linux, situation might be better.
Old   July 16, 2005, 08:45
Razvan
That's what I keep saying to myself.
I made some interesting tests lately: Sciencemark 2, 32bit and 64bit versions. What I immediately noticed was:
- some tests revealed good improvement in 64bit version, some extraordinary improvement(for example, "molecular dynamics" test results: 76 seconds/32bit, 28 seconds/64bit !!!)
- CPU utilization 100% all the time in 64bit version (it was an interesting thing to notice that 32bit Fluent is not fully utilizing the 2 CPUs)
You may be right, I should change track to 64bit Linux + 64bit Fluent.
Thanks a lot! Razvan
Old   July 19, 2005, 12:13
Luke
Try 32-bit Windows XP Professional. Win x64 can run only native 64-bit code, for 32-bit programs(like Fluent 6.2.16) it uses WOW32 emulator.
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 04:22
Abaqus - Fluent Coupling WITHOUT MPCCI s.mishra FLUENT 1 April 5, 2016 07:47
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 17:41
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 07:41
running Fluent on a DUAL CORE system Ralf Schmidt FLUENT 3 June 20, 2006 11:21
