UDF Compile Error
Old   July 13, 2005, 14:11
Default UDF Compile Error
Quak
Hi, I tried to compile my UDF and there is a message said: (chdir "ntx86\3d")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.
Done.
Opening library "reactor-libudf"... Error: open_udf_library: The system cannot find the file specified.
Error Object: ()
Can anyone know what the problem is? Thanks Quak
Old   July 13, 2005, 14:20
Default Re: UDF Compile Error
pUl|
You need MSVS. search this forum using the keywords:
'nmake' is not
You'll find the answer to your problem.
Old   July 14, 2005, 13:35
Sandra
it's possible that your compiler and fluent are not in the same directory.
Old   July 20, 2005, 09:31
Mahesh
Install VC++ v6.0 with service pack and set all the environment variables.
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 19:54
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 07:12
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
