July 13, 2005, 09:01 |
meshing for flow past a cylinder
hi how to do the meshing for a flow past a cylinder or sphere where the object is fully closed and flow goes around it...suggestions wud be highly appreciated... thanks a lot..
July 15, 2005, 07:17 |
Re: meshing for flow past a cylinder
I am modelling the same problem. The way I do it is I use hexahedral mesh with a finer mesh around the cylinder. You also need to take into consideration the geometry of your model.
Sham. |
flow over a cylinder urgent! | kevin | FLUENT | 8 | August 11, 2015 14:00 |
Flow past 2 smooth circular cylinder | slip | FLUENT | 0 | July 8, 2010 19:45 |
[blockMesh] Meshing inside a cylinder so that the edges contain more cells than the center | Bertrand | OpenFOAM Meshing & Mesh Conversion | 1 | April 13, 2010 05:46 |
Flow past cylinder (Re=10^5) | lbeaudet | Main CFD Forum | 9 | June 2, 2009 04:59 |
Best Meshing scheme for Cylinder | Nutrex | Main CFD Forum | 4 | July 29, 2008 12:03 |
