Annular multiphase flow
Old   July 12, 2005, 05:25
Default Annular multiphase flow
John
I am trying to model gas through a pipe, with a thin layer of liquid on the inside of the pipe (annular flow). Therefore, there is a clear interface between the two phases, and are not inter-penetrating.
Can I model this using the VOF model? I query this because I want the 2 phases to move at different speeds, and I dont think the VOF allows me to do this.
Thank you in advance.
Old   July 14, 2005, 08:43
Default Re: Annular multiphase flow
Ejaz Ahmed
Hi John
i think you should define two different zones in gambit while making goemetry. then define two fluid for each zone. Now you can apply different velocities to each phase.
your case doesnot lie in the domain of multiphase flow.
With Regards
Ejaz Ahmed
Old   July 14, 2005, 23:59
Benny
I think VOF is better!
Old   July 15, 2005, 05:23
John
Yes I am now aware that with the VOF model you can have the 2 phases moving at different speeds, but they are the same velocity at the interface. (at the interface there are small liquid particles moving at same velocity as the gas phase at the interface)
Thanks for all your help.
Annular Flow in Pipes metro OpenFOAM Running, Solving & CFD 0 August 11, 2010 04:34
Disturbed flow field at outlet boundary (Multiphase flow through pipe) Michiel CFX 17 April 21, 2010 11:14
multiphase flow, aeration Ellie CFX 3 January 15, 2009 18:33
How to model two-phase annular flow? Zhang FLUENT 0 March 6, 2007 16:41
VOF Annular Flow Mark FLUENT 0 May 2, 2006 09:59
