Multiple frame reference in stirred tank reacto |
July 7, 2005, 09:40 |
How do i specify my boundary conditions in GAMBIT when i am intending to use MFR in FLUENT?
I had to two blocks(inner & outer). The inner contains the impeller & shaft and it is rotating one while the outer is the stationary which contains the baffles. I specifed my blades & shaft as moving wall with relative velocity adjacent to zone as zero. There is an interface which i created but my solution is not converging. I guess it is my boundary conditions or creation of the outer or inner blocks. I need help. |
July 7, 2005, 11:29 |
Re: Multiple frame reference in stirred tank react
There are two points you can check:
Is your grid ok after you set the interfaces? You can check this with the command grid -> check. The MRF is more suitable to problems with small rotor/stator interaction. You can try to use sliding mesh if your interaction is strong. Good luck galeazzo |
July 8, 2005, 05:57 |
Thanks. My tank height is about 300mm. Can you advise me on how i can restructure my grid. How do i create this interface?
Expecting |
July 11, 2005, 16:22 |
There is a Fluent tutorial on how to set a sliding mesh problem. If you have access to the www.fluentusers.com, the URL is http://learningcfd.com/login/fluent/...iding-mesh.pdf
If not, I can send you the file via email. I think it is enough to you to set your problem properly. galeazzo |
June 1, 2010, 16:47 |
tutorial on multi frame reference
lalit upadhayay
Please send me the tutorial on MRF at my mail lalitupadhayay@rediffmail.com. i will be very grateful to you..
Regards |
Second Derivative Zero - Boundary Condition | fu-ki-pa | OpenFOAM | 11 | March 27, 2021 05:28 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
G95 + CGNS | Bruno | Main CFD Forum | 1 | January 30, 2007 01:34 |
Stirred tank with baffles simulation using single rotating reference frame | M.Zhou | FLUENT | 1 | March 5, 2000 16:01 |
