July 7, 2005, 07:20 |
Jump in residuals under Linux
Hi, I have a problem. Maybe has somebody an answer. Ok I describe the problem: Under Linux, I read my case, which has non-conformal interfaces, I iterate, and I write data. If now I re-read my data, and iterate more, all my residuals explode (ie: jump in my residuals). I didn't change any parameters in my .cas file That means, I can't pursue my calculations. Any idea? Thanks mAx
July 8, 2005, 02:03 |
Re: Jump in residuals under Linux
Hi, I think I know where the problem is. If I stop the calculations, check for instance a force on a piston, then write data.... then reread data, re-check the piston's force... i don't get the same result (and the pressure distribution has been corrupted). Does Anyone have the same problem???? I am running under Linux x86 & Parallel Thank U mAx
July 11, 2005, 11:15 |
Do you save only .dat file?
July 12, 2005, 01:53 |
yes, just like autosave does. But I have no moving mesh, ie: my grid is still the same
July 12, 2005, 08:54 |
Are you using the command
if PRINCIPAL_FACE_P(f,t) inside the force loop ? |
July 12, 2005, 08:57 |
No... I am in contact with support, but they never have seen that before...
July 12, 2005, 09:47 |
if you want try it:
#if !RP_HOST ID = IDvd1; tv = Lookup_Thread( domain,ID ); begin_f_loop(face,tv) if (PRINCIPAL_FACE_P(face,tv)) { F_AREA(area,face,tv); total_force += NV_MAG(area) * F_P(face,tv); } end_f_loop(face,tv) #endif node_to_host_double_1(total_force); |
July 12, 2005, 09:51 |
I forgot:
total_force = PRF_GRSUM1(total_force); |
July 12, 2005, 09:55 |
#9 |
If you get the same kinds of error, I assume it is because of an error PR_GRSUM1(total_force), which is supposed to add the force computing from each node. So normally the force computed shouldn't change if you run your case under 2,4 or 8 CPU. In my case I don't have any UDF...
sudden jump in residuals | wlt_1985 | FLUENT | 8 | June 26, 2014 04:51 |
Jump in Residuals | ryzd | FLUENT | 1 | March 1, 2011 21:39 |
Dual Boot Windows and Linux and Go Open Source | andyj | Main CFD Forum | 2 | October 21, 2010 16:49 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
Fluent Parallel/Serial version..jump in residuals | Sandeep Abhyankar | FLUENT | 4 | January 10, 2000 09:57 |
