July 6, 2005, 05:22 |
RNG LES
Some time agao i posted a question asking how to enable rng-les. i did not get any reply. anyway now i have found the way to do it, if someone needs here is the way:
1. start fluent. 2. select les model in viscous panel 3. execute this scheme command in TUI (rpsetvar 'les-rng-sgs-on? #t) 4. read the mesh file, fluent will now prompt that rng model is now availble in interface. |
June 2, 2021, 10:18 |
SV
Rep Power: 14 |
The command is (allow-rng-subgrid-model) type into TUI with brackets.
Turbulence dampening due to magnetic field in LES and RAS | eelcovv | OpenFOAM | 0 | June 8, 2010 12:35 |
why RNG k-e is better & what does RNG really mean? | Bonnie White | FLUENT | 1 | August 8, 2006 10:14 |
rng les | zxaar | FLUENT | 0 | May 18, 2005 02:16 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 09:10 |
Some Questions about LES. | Bin Li | Main CFD Forum | 2 | February 20, 2004 10:58 |
