Accelerate convergence in coupled solver
Old   June 23, 2005, 02:22
Default Accelerate convergence in coupled solver
Balaji
HI,
I am using Coupled solver for my simulations.I have seen that the residuals of Continuity, momentum and energy are converging very slowly. Is there any way to accelerate convergence in coupled solvers.
Thanks in advance
Old   June 23, 2005, 03:57
Default Re: Accelerate convergence in coupled solver
Luca
You should raise the Courant number but pay attention the solution may diverge if it's too high. Anyway if you look at the manual you see coupled residuals are defined in a different way from the segregated ones. This is why segregated residuals always appear smaller than the coupled ones and this could be misleading. Luca
Old   June 23, 2005, 04:53
Balaji
I increased the courant number from default value of 5 to 50 it converges fast.when I increased still high value solution got diverged. Is there any criteria to choose the courant number.If I want to solve some other problem I may not use the same courant numbers.
Thank you for your reply.
Balaji
Old   June 23, 2005, 19:16
Tang
You could try FMG initialization in 6.2.
Coupled and Segregated solver soe FLUENT 2 March 8, 2007 05:37
The seperated solver and coupled one summer FLUENT 0 July 5, 2006 16:06
Can I use coupled solver for this problem Frank FLUENT 0 April 11, 2006 07:28
Convergence with coupled implicit solver Henrik Ström FLUENT 1 October 29, 2005 04:57
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
