turbulance
Old   June 17, 2005, 07:26
Default turbulance
Eureka
Hi, i have very simply geometry, two line horizontal parrallel 1 cm far.The upper move at costant velocity at the finish of simulation ( residual ~ 1e-14) i report the force to pull the upper line and the force to take stationary the bottom line. i use laminar model for viscosity. i have found that at v=0,004 m/s two Force are very different, while at v=0,00004 m/s the two Force are similar ( to evaluate the force i have subtract the inlet zone initial line over and initial line under to minimize the edge effect) this is turbulance?? plz help me it's importat thank you
Old   June 18, 2005, 07:10
Default Re: turbulance
Mehdi Ghoddosy
Dear Ereka: In this range of reynolds number there is no turbulence and so you don't need any turbulence modeling. However, no turbulnce effect could be seen while you use a turbulnce modeling even if you have a turbulent flow in real.
Your velocity is too small (0.00004) and numerical diffusion can change your answers. the changes could be arised from this. Also you should not give same force on the two plates in couette flow problem.
Regards
How to choose the Turbulance Intensity if I know RE number? adam_annie CFX 1 January 24, 2010 20:17
turbulance model nathan FLUENT 1 May 1, 2007 09:50
specifying turbulance from laminar asghari Main CFD Forum 5 February 14, 2007 04:17
turbulance model J.subramani CFX 1 January 4, 2004 18:00
Turbulance parameters irfan CFX 1 November 18, 2002 03:16
