June 16, 2005, 12:06 |
UDF in Parallel
I am using parallel computing on two Windows XP Pro. I compiled my UDF in Parallel Fluent with 2 nodes enabled. Log tells me that the compilation is successful. When I load the UDF library, Fluent hangs on for ever.
If I spawned two nodes on one of computer (i.e. using SMP), the UDF can be loaded successfully. I shared the working directory where UDF is located. It still does not work. Anyone could please give me some advice? Thanks, Gavin Yang |
June 19, 2005, 23:17 |
Re: UDF in Parallel
hello.
I had same problem when rshd setting was wrong. I don't know it so much, but User's guide(32.4.1) might help you. good luck!! |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 23:14 |
udf compile in parallel system | tahereh | FLUENT | 1 | December 9, 2008 10:48 |
Help: how to realize UDF on parallel cluster? | Haoyin | FLUENT | 1 | August 6, 2007 14:53 |
Parallel Fluent +UDF | Jack Martinez | FLUENT | 0 | June 28, 2007 12:19 |
UDF in parallel version. | yobee | FLUENT | 0 | August 17, 2004 05:12 |
