LES concentric annulus
Old   June 14, 2005, 15:48
Default LES concentric annulus
Alex
Hi. I'm trying to LES a concentric annulus flow using periodic BC. Actually, I'm talking about two pairs of periodic BC faces (don't want to mesh the whole 360). One in the flow direction (X)-parallel to the axis and the other on the sides of say 30 degrees sector which should be at 30 one to the other. Is there going to be a problem in Fluent? I.e. will it be enough to define flow in X direction in the periodic BC and it will be equal velocities etc. at the second pair of faces? Thank you.
Single annulus concentric cylinder Satya prakash Main CFD Forum 0 February 3, 2011 01:40
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
Problem with Eccentric pipe annulus..Pls Help me Parag Ramteke FLUENT 2 April 4, 2005 07:34
Turbulent concentric annulus JonS Main CFD Forum 3 August 10, 2004 08:02
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
