where to setting the slip wall in udf
Old   June 14, 2005, 09:59
Default where to setting the slip wall in udf
cxzhao
now i have a udf to define slip velocity of slip boundary condition, can anybody tell me where can a adding this udf in fluent under Boudary condition plane.
Old   June 14, 2005, 11:58
Default Re: where to setting the slip wall in udf
pUl|
Define -> Boundary conditions -> Wall -> Choose the appropriate phase (not mixture) if you are simulating Two-Phase flow -> click on Set. Under SHEAR CONDITION, choose 'specified shear' and then change constant to udf by clicking on the drop down box.
PS: I would like to access this code if it is possible. Can you email (msrinath80@yahoo.com) it to me?
Old   June 14, 2005, 22:36
cxzhao
ok,thanks, i will sent it to you at once.
Old   June 15, 2005, 11:09
pUl|
My email address is msrinath80@yahoo.com.
Old   July 4, 2005, 03:56
cxzhao
what i should choose if i simulating single-phase flow.
specified shear at wall - temperature gradient - UDF - access violation error senD Fluent UDF and Scheme Programming 9 September 18, 2014 08:29
Accessing wall shear stress using UDF Robert Fluent UDF and Scheme Programming 2 July 31, 2013 09:34
udf variable for wall temperature Kiran FLUENT 0 July 31, 2008 09:31
UDF for oscillating wall Rajneesh FLUENT 0 February 21, 2006 22:44
wall conduction, UDF sudh FLUENT 0 June 28, 2004 09:09
