64 Bit machine
Old   June 13, 2005, 11:29
Default 64 Bit machine
P
My department has boungut AMD linux 64 bit processor. In each computer we have two processor. I want to run Fluent in parallel in these two processor in a computer.
Please tell me is it possible?
P
Old   June 13, 2005, 14:08
Default Re: 64 Bit machine
pUl|
Yes.
Try 'fluent version -tnprocs'
Where version is 2d, 2ddp, 3d etc. and nprocs is to be replaced by the number of processors.
For instance, for a 3 dimensional problem in a dual processor system you would type:
fluent 3d -t2
Old   June 13, 2005, 16:59
Evan Rosenbaum
Sure, as long as you have enough licenses. Each CPU takes up a seat.
Old   June 14, 2005, 11:55
Jason
You can also buy parrallel licenses. They are much cheaper than buying an entire second license.
Jason
Old   June 14, 2005, 15:02
P
Well my question is if I have parallel license it is possible to run fluent in parallel version in these two processor or not.
P
Old   June 15, 2005, 09:21
Jason
I'm not an expert, but from what I've heard on the forum, people are using 64-bit AMD machines. I would think that you wouldn't have any problems (assuming its set up correctly and you have the proper licenses).
Only way to know is to try, and if you run into problems, then post your problem on here, and someone may know how to fix it.
Good luck, Jason
Old   June 15, 2005, 10:40
Aaron
If its a Linux OS and you have a message passing interface software (and network interconnect card if the processors are on separate nodes), then you can. If not, then I think you can't. If you have Windows, then I don't know, but I believe you would still need some way of passing messages through a "traffic cop" so the two processors could know how to communicate with one another.
For your purposes, it should be easy to obtain a "network" message passing interface (NMPI). There are many free ones available, such as ROCKS, which comes from the San Diego supercomputing center --> http://www.rocksclusters.org/Rocks/
Old   June 24, 2005, 14:17
Arun
You can run parallel process on two processors. If you are using a single memory for both processors, then you can run Shared MPI which is much faster than Network MPI.
[OpenFOAM.com] OpenFOAM-1.6.x on 64 bit machine Kr_kim OpenFOAM Installation 7 August 25, 2016 03:40
anyway to install 32 bit fortran on 64 bit machine HaKu Main CFD Forum 4 July 22, 2011 08:30
CFdesign software for 64 bit machine M_Marivani Autodesk Simulation CFD 0 April 20, 2006 10:50
Run Fluent on a 64 bit machine Fluentuser FLUENT 10 March 17, 2006 11:18
To run FLUENT in a 64 bit machine Rucy FLUENT 1 June 25, 2005 15:17
