connect two udf to one
Old   June 11, 2005, 05:31
Default connect two udf to one
gaoshan
i wanna set the inlet and the outlet boundaries using two different udfs,but fluent only know the last one, so how can i connect the two udf into one file udf? thanx~~
Old   June 11, 2005, 06:09
Default Re: connect two udf to one
dirk
You have to put both into one .c file.
Old   June 12, 2005, 02:13
gaoshan
they all pass seperatelly,but when put into one .c flie,in report line 6 parse error,,
BTW,i haven't put on the C LANGUAGE SOFTWARE,,
THANKX
problem loading UDF library in parallel cluster Veera Gutti FLUENT 8 July 26, 2016 08:24
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
