Gambit mesh for cylinder
Old   June 10, 2005, 13:19
Default Gambit mesh for cylinder
Kavia
dear friends,
When I mesh a cylinder with cooper, how can I control the mesh size in the axial direction ? I can not find the option to do so ( I generated the cylinder directly and mesh the two bases)
Old   June 10, 2005, 13:28
Default Re: Gambit mesh for cylinder
Thiyaga
Hi, try to mesh the side wall first, then go for bases. regards..
Old   June 10, 2005, 16:22
anindya
It depends on how you generate the cylinder. If you creat a cylinder using the 3D cylinder model generation in gambit directly, you have problems meshing in the axial direction.
I would suggest that you great a circle with a diameter equal to that of the cylinder. mesh the cirle as you would like it to be. Then protude the cirlce in the direction you want for the length of the cylinder and choose the option (with mesh). In that way you will generate a cylinder that will have both the upper and lower circular surfaces meshed. Now you can also specify the mesh as you like for the length (axial direction).
Old   June 12, 2005, 23:59
pah
Hi Kavia and everybody!
I made the mesh for cylinder in 2D and 3D, and I think you can make Cylinder 3D by using Extrude from 2D in the direction that you design (in 2D I did not make a full circle, it exists 4 parts). From there, you have some Edges in the axial direction, they can be controled by your distribution. Best regard!
pah
Old   June 13, 2005, 14:00
Kavia
Thanks for all of your reply. Could you tell me where is the extrude option in the GAMBIT ? I can't find it.
Old   June 13, 2005, 22:24
zxaar
well i have been doing lot of meshes for cylinders and to use cooper with the kind of mesh you want you have to cut the cylinder into four parts (the circular section into four 90 deg sectors), now once you have these sectors, describe the distribution on the edges in the direction to creat prism meshes, and just use cooper tool to create the mesh, for smooth cylinders its as easy as 10 mins job
Old   June 14, 2005, 07:22
pah
Yes!
The Extrude command You can find in the generation Volume button. Or you can contact to me, if I can, I will help you. hungaerospace@yahoo.com
pah
Old   June 19, 2005, 01:31
Mehdi Ghoddosy
Dear Kavia:
I suggest use down-top approach(first creat cap circles). now,you can split the cap circle into for curves at 45 degree.Then change these vertex types to END. THen split the curves on the top and bottom at +90 and -90.Now you have 6 curves. grade the four edges in the top and botom to achive finer mesh at corners. Now you can mesh these circle using map scheme. and then mesh side faces and use cooper scheme to mesh the volume. In this way you can control mesh sizes in all directions.
REgards
Old   December 29, 2010, 07:14
Default Hi anindya
zeeshan
zeeshanboom is on a distinguished road
Plz elaborate how can we mesh in axial direction once we have extruded 2D circular mesh in axial direction.
Thnx and Regards
Originally Posted by anindya
;121441
zeeshanboom is offline   Reply With Quote
Old   January 3, 2011, 02:04
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
in Fluent or in Gambit?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   January 3, 2011, 02:42
Default meshing this geometry in gambit
  #11
zeeshan
Since last week am stuck in meshing this geometry, its riser of a circulating fluidised bed. The two extruded small pipes are soild inlet and gas-solid outlet. The bottom of riser is gas inlet and top is wall. i want very fine grid near wall.
I have tried following approaches but failed :
a.)unstructured grid, directly meshing using vol. mesh.
b.)Boundary layer (i didn't understood how to apply it ).
c.)Created a circle wid 4 sectors and then meshed them separately but problem is now i have 4 meshes how wud i join them?
Please help am beginner in Gambit and a big fan of this forum.
Regards
Zeeshan
Old   January 3, 2011, 02:49
-mAx-'s Avatar
Maxime Perelli
You cannot mesh directly your geometry with hexa
Check Tutorial 7 from Gambit: Modeling Flow in a tank
Old   January 3, 2011, 03:01
Default 'll give it a shot :)
  #13
zeeshan
Thnx Max!
Regards
Zeeshan
Old   February 3, 2011, 17:58
daalou
alilouu is on a distinguished road
THE ONLY SOLUTION WITHOUT TRYING TO redrawing the cylindre is to tick
pro intervals, if yu need 10 elements in the axial direction, tick 10
good luck
alilouu is offline   Reply With Quote
Old   September 10, 2011, 12:42
jbr
jonbonraki is on a distinguished road
hi all i have the following error while trying to open the gambit, can u please tell me hoe do i fix it.
gambit XIO: fatal IO error 0 (Winsock Error) on X server JONBONRAKI-PC:0.0
after 0 requests (0 known processed) with 0 events remaining.
jonbonraki is offline   Reply With Quote
Old   September 26, 2013, 01:16
Default how about the cylinder imported from Autocad
  #16
kkpal is on a distinguished road
hi,
I'm having a problem with meshing a 3-D cylinder with adaption(like helix) imported from Autocad .sat file.
Since the cylinder is imported in gambit as a whole volume, there is no edge on the cylinder in the axial direction.It is difficult to control the mesh quality in the axial direction.
any one knows how to solve this problem?
kkpal is offline   Reply With Quote
Old   September 26, 2013, 01:34
-mAx-'s Avatar
Maxime Perelli
do some splits
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
How to mesh a circle by Gambit? Zhengcai Ye FLUENT 5 March 24, 2006 02:04
[Commercial meshers] Mesh import from gambit Kaushik Balakrishnan (Balakrishnan) OpenFOAM Meshing & Mesh Conversion 5 April 21, 2005 14:42
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
