Extracting nodal values from a plane!!
Old   June 10, 2005, 03:34
Default Extracting nodal values from a plane!!
Thundil
Hi all,
Iam using Fluent6.1.In postprocessing,i would like to get the nodal values of velocity in a plane i created.Bcos, i want to export this data file to techplot for comparing with experimental value obtained with PIV. thanks for your time regards Thundil.
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Extracting Stream Function from nodal u,v data Abhijit Tilak Main CFD Forum 5 March 8, 2004 17:13
high difference between cell and nodal values Trilok FLUENT 2 November 13, 2003 04:38
nodal temperature values Mcgregor FLUENT 0 May 5, 2003 09:19
