UDFs' problem
Old   June 3, 2005, 10:12
Default UDFs' problem
Benny
Hi all,
If I want to get the temperature of cells which are adjacent to the wall, how could I achieve it?
Best regards!
Benny
Old   June 3, 2005, 10:51
Default Re: UDFs' problem
dirk
For what do you need these temperatures?
Old   June 3, 2005, 11:02
Benny
I need the temperature for I want to calculate the htc.
Old   June 3, 2005, 11:10
dirk
It is available under wall fluxes. You dont't have to compute them with UDF.
Dirk
Old   June 3, 2005, 11:35
Benny
I found that the result of Surface Heat Transfer Coef. is not right. It's defined by h=q/(T_wall-T_ref), where T_ref is the fluid average temperature. But I think if the T_ref is near walltemperature, the result will be better.
Old   June 3, 2005, 13:21
DH
There is a routine which allows you to get the c0 and c1 cells for any given face. You would need to loop through all the faces on the given cell and get the c0,c1 temperature for each adjoining cell. Note, the looping order for cells interior to you domain and those at the boundarys will have different looping orders. This type of looping and calling the adjacent cells to a face is in the fluent udf manual.
cheers,
DH
Old   June 3, 2005, 15:29
us
see example in , 4.3.21 section of UDF manual(F6.2)
Old   June 3, 2005, 23:48
Benny
Thank you all for your help! could you show me what DEFINE Macros I should use to get the value? I need more info in details.
Dear us, could you post the example here, for the version I use is 6.1.22. Thank you again1
Best regards!
Benny
Old   June 4, 2005, 22:56
forest
I think DEFINE_ADJUST could do that. There should be other ways as well.
Old   June 6, 2005, 11:03
us
You can find the information on the macro in 6.1 UDF manual too. Pl. refer 5.2.2 for all the necessary information. The example i was talking about, there is the same example in 6.1 udf manual too. Refer 4.3.19. Just in case, i hv copy pasted the example here. --------------
UDF that implements a simplified advective term in the
scalar transport equation ************************************************** *********************/
#include "udf.h"
DEFINE_UDS_FLUX(my_uds_flux, f, t, i) { Thread *t0, *t1 = NULL; cell_t c0, c1 = -1;
real NV_VEC(psi_vec), NV_VEC(A);
/* neighboring cells of face f, and their (corresponding) threads */
t0 = THREAD_T0(f,t); c0 = F_C0(f,t);
if (NULL != THREAD_T1(f,t)) /* Alternative: if (! BOUNDARY_FACE_THREAD_P(t)) */
t1 = THREAD_T1(f,t);
c1 = F_C1(f,t);
} else
t1 = NULL;
c1 = -1;
/* If Face lies at domain boundary, use face values; */ /* If Face lies IN the domain, use average of adjacent cells. */
if (NULL == t1) /* Alternative: if (BOUNDARY_FACE_THREAD_P(t)) */
NV_D(psi_vec, =, F_U(f,t), F_V(f,t), F_W(f,t));
NV_S(psi_vec, *=, F_R(f,t));
} else
NV_D(psi_vec, =, C_U(c0,t0), C_V(c0,t0), C_W(c0,t0));
NV_D(psi_vec, +=, C_U(c1,t1), C_V(c1,t1), C_W(c1,t1));
NV_S(psi_vec, /=, 2.); /* averaging. */
NV_S(psi_vec, *=, (((C_R(c0,t0) + C_R(c1,t1)) / 2.)));
/* Now psi_vec contains our "psi" from above. */ /* Next, get the face normal vector: */
F_AREA(A, f, t);
/* Finally, return the dot product of both. */ /* Fluent will multiply the returned value */ /* by phi_f (the scalar's value at the face) */ /* to get the "complete" advective term... */
return NV_DOT(psi_vec, A); }
Old   June 6, 2005, 13:04
  #11
Benny
Hi us!
Thank you very much!
Best regards!
Benny
Old   June 7, 2005, 08:53
  #12
Mahesh
If U know the temperature of the wall, give it in Reference panel and then u can get htc. Otherwise, U can write one custom field function for the same.
Old   June 7, 2005, 10:47
  #13
Benny
dear Mahesh,
I think the most difficult thing is to get the temperature of the nodes adjacent the wall. I think the reference temperature should be the temperature of the nodes adjacent the wall, not the one of fluid.
Old   June 13, 2005, 08:28
  #14
zubier
would you please show me how to use the user defined scalar to model electrical field inside the heating cell ontaining fluid means that how to use c language to write this subroutne program with my best regard
Old   June 13, 2005, 12:05
  #15
us
I can give you some literature reference where electrostatic field was modelled using User defined scalar. But it was for the application of electrostatic powder coating process. However, atleast you'll get some idea.
Ye, Q., Steigleder, T., Scheibe, A., and Domnick, J., 2002, Numerical simulations of the electrostatic powder coating process with a corona spray gun, J. of Electrostatics 54, 189-205.
Bottner, C.U. and Sommerfeld, M., 2002, Numerical calculation of electrostatic powder painting using the Euler/Lagrange approach, Powder Technology 125, 206-216.
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
problem in UDF's sangamnath FLUENT 3 December 7, 2005 10:17
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
