How to import PARTRAN file to Gambit?!
Old   May 31, 2005, 06:11
Default How to import PARTRAN file to Gambit?!
anisa
Hi, everybody! I'm starting user of Gambit and Fluent. One colleague has sent to me PATRAN file with ready mesh. When I import it to fluen I can't determine a boundary conditions. I can determine a boundary conditions at Gambit. How to import Patran file to Gambit? Yours frd.
Old   June 1, 2005, 11:16
Default Re: How to import PATRAN file to Gambit?!
Mark
You can import a PATRAN Neutral file using the following menu
->File
->Import
->Mesh
Then specififying the type as PATRAN and Dimension as either 2D-planar surface mesh, 3D-volume mesh or 3D-Surface mesh. You must also specify a featuring angle.
Good Luck
Mark
Old   June 1, 2005, 12:52
anisa
Dear Mark, Patran file has pat extension.If I do that you written above, in Gambit needs a neu extension and pat extension is unvisible ...
Old   June 6, 2005, 11:58
Mark
You will need to generate a PATRAN neutral file before you can import it into fluent/gambit. This acan be done inside PATRAN using the /file/export menu.
Regards
Mark
Old   June 7, 2005, 05:24
anisa
Thanks Mark very much, I understand everythink
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
How to make a dat file to import to Gambit Elham ANSYS Meshing & Geometry 2 November 7, 2009 01:32
