May 31, 2005, 00:14 |
HELP: How to get Heat transfer Coefficient?
Hi all,
I don't know how to get the value of the HTCs in Fluent. Could somebosy help me? Thank you ahead! |
May 31, 2005, 03:30 |
Re: HELP: modeling electerofilter
hi how can i model the electrofilter by fluent. if you have any answer i want to call me by yahoo messenger.i am online.
June 1, 2005, 12:06 |
Re: HELP: How to get Heat transfer Coefficient?
Hi Benny!
You are able to specify different boundary conditions for the temperature. E.g. konstant wall heat flux... The HTC will bew calculated from these bc's... Or do you want to set it as bc? Sorry for my poor English... |
June 3, 2005, 04:07 |
Hi Korni,
Yes, it seems that it's quite easy to obtain the HTC in the fluent, but I found that the value I obtained is not right. So I hope somebody could hele me to obtain the right value. |
June 6, 2005, 12:42 |
You need to set the reference values for Temperature, etc to represent the bulk flow. Alternatively, you could use the new wall function based HTC calculation.
Regards Mark |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 17:29 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 23:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 16:55 |
