HI EVERYBODY! I've a question about a problem I'm having with a 3d grid.
When I try to mesh a volume, the following message appears: "Initialization failed;perturb boundary nodes and try again. Initialization failed to mesh 40 nodes." and I can mesh my volume. I have tried to modify the number of interval count on the edges and I've got the same message but the number of nodes that can not be meshed are 2 and not 40. I don't know if this strategy to reduce this number is correct and anyhow I'm not able to eliminate totally the non meshed nodes, Have you any suggestion? Thanks a lot Best Regards Antonietta Paulozza ----- Original Message |
Try smoothing the face mesh using a LW laplacian scheme. under mesh>face>smooth mesh.
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 03:19 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 11:45 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
2d irregular grid | Remy | Main CFD Forum | 1 | December 22, 2008 04:49 |
Grid check fails after sliding mesh calculation | Tito | FLUENT | 0 | March 3, 2008 14:28 |
