Hi there,
does anyone here have some experience with running Fluent 6.2 on debian linux? It seems to work fine here, but at startup I get some error messages/warnings about the missing rpm packet management and an "domainname: command not found". Are those just cosmetic errors or do they influence my work with Fluent? Any comments would be appreciated. Best regards, Chris |
These startup errors are not related to Fluent in any way, unless when you start fluent you get these errors on the console.
PS: It is finally nice to see someone using Debian GNU/Linux ![]() |
Install what ever it is asking for using apt-get and the messages should vanish. There are some optional rpms which are used, which do not affect the computation but for the decorative and other purposes.
-H |
Thank you both for your response.
I partially solved the problem by installing rpm (which now complains about not being able to access its database, although I created it) and softlinking dnsdomainname (which is in debian) to domainname (which is expected by Fluent). Chris |
Fluent - Linux vs Windows | derick | FLUENT | 2 | August 16, 2020 11:23 |
Fluent on a quad core with debian | Ralf Schmidt | FLUENT | 4 | April 21, 2008 03:23 |
Fluent on Linux Cluster | george | FLUENT | 0 | August 11, 2006 04:57 |
Moving Dynamic Mesh in Fluent 6.2 | R.M.Bharath Somayaji | FLUENT | 0 | January 9, 2006 20:36 |
Running Fluent on Red Hat Linux WS version 4 | Bob | FLUENT | 1 | September 4, 2005 05:01 |
