Cannot preview the dynamic mesh
Old   May 25, 2005, 06:27
Default Cannot preview the dynamic mesh
sam
Hi, i am new to this dynamic mesh udf feature and i have a simple problem like i want to move a piston in a larged cylinder using a dynamci mesh feature.I am using FLUENT 6.2.16. when i compile it gives no error and successfully loaded.I have even tried to preview the mesh with a small time step but in vain.The dynamic mesh parameters i have used in my problem is that i used remeshing and smoothing algorithm. The dynamic zone i have used is that i defined the piston as rigid body and hooked my udf with this boundary. Can anyone help me in this matter. I will appreciate any help and associated examples with this features.
My code is like that:
#include "udf.h" #include "dynamesh_tools.h" DEFINE_CG_MOTION(piston, dt, vel, omega, time, dtime) { /* reset velocities */ NV_S (vel, =, 0.0); NV_S (omega, =, 0.0); if (!Data_Valid_P ()) return; vel[0]= 0.4 ; }
Old   May 25, 2005, 08:52
Default Re: Cannot preview the dynamic mesh
Saad bin Mansoor
If you are using quadrilateral meshes then remeshing won't work. Instead you have to use layering. Further you can use smoothing instead of layering but smoothing has to be activated for a qaudrilateral mesh by the command-line statement
def/mod/dmc/smp/spr, Enter a yes to activate smoothing for quadrilateral cells.
Sincerely, Saad
Old   May 25, 2005, 13:54
sam
well dear thanks for replying, further in addition to the last message, i am using the triangular mesh in the domain and near the object i use boundary layer and its only 2d problem.please help me in this matter and give me some samples of such kind of problem if you can. I am really thankful to u Mr. Saad bin Mansoor .
Old   May 26, 2005, 06:12
antun
Hi
Check that the adjacent wall/axis is defined as 'deforming'.
Old   May 26, 2005, 07:58
sam
in my case there is no axis, it is rigid body motion problem having linear velocity in x-direction.
pls help. mesh collapsed with dynamic mesh. wlt_1985 FLUENT 2 May 7, 2020 11:42
Fluent dynamic mesh 'remeshing' method for pyramid elements DarrenC FLUENT 14 December 11, 2015 05:58
Dynamic mesh is not getting updated. cardio FLUENT 1 May 20, 2014 09:41
Some questions about mesh updating in dynamic mesh technique lzgwhy Main CFD Forum 0 June 14, 2009 09:01
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 16:40
