May 19, 2005, 02:42 |
how to
some turbulence models are not directly available in the GUI, such as low Re-ke model,how to activate these models?
May 19, 2005, 07:49 |
Re: how to
You have to use text interface.
Dirk |
May 20, 2005, 07:29 |
Re: how to
Thank you
but,what is text interface? |
May 20, 2005, 14:16 |
Re: how to
May 21, 2005, 13:23 |
Re: how to
Hi
define/model/viscous/mixing-length y It can active the tuburlent mixing length define/model/viscous/tuburlence-excerpt/low-relke y can it active the low Re model? Thanks |
May 21, 2005, 19:34 |
Re: how to
Yes, you can specify which low Re formulation you need etc.
May 21, 2005, 19:35 |
Re: how to
Oh I forgot... Just choose the appropriate index for the model you need.
May 21, 2005, 22:07 |
Re: how to
does anybody know how to activate rng-les
May 22, 2005, 04:28 |
Re: how to
#9 |
Thank pUl
