error of Parallel fluent in 3d -t2!
Old   May 18, 2005, 09:49
Default error of Parallel fluent in 3d -t2!
sanmango
Hi! I had made a parallel simulation in a 2CPU compute.When fluent read the case (.cas) in auto partition ,there were such errors :
Parallel variables... Building...
grid,
auto partitioning mesh by Principal Y-Coordinate,
distributing mesh
parts..,
faces.., 999999 (..\..\src\mpsystem.c@1228): mpt_read: failed: errno = 10054
999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument
Process [0] exited with status [-1073741819] Process [1] exited with status [259] MPIRUN exited with status [126] The Parallel FLUENT process could not be started.
Why so? And how to deal with?
Old   May 18, 2005, 12:26
Default Re: error of Parallel fluent in 3d -t2!
us
I also had such problem. What I understood is, it is due to the insufficient memory. I obserbed that when i did partitioning for the same case with 2 CPUs but with higher allocated memory, everything was ok. Also, i tried with reduced number of cells in the domain, on the machine with relatively low memory, again everything was fine. So probably, memory problem in your case.
regards, -US
Parallel running of Fluent Bhanu Gupta FLUENT 3 April 7, 2011 10:32
Parallel Fluent +UDF Jack Martinez FLUENT 0 June 28, 2007 12:19
Fluent Parallel SUPPORT MOHAMMED TOLBA FLUENT 1 February 20, 2006 02:27
Parallel Fluent with Mandrake Daniel Dotta FLUENT 1 May 19, 2005 16:30
error parallel fluent session Diet FLUENT 2 January 27, 2005 13:31
