Calculate Pressure force
Old   May 16, 2005, 06:40
Default Calculate Pressure force
andreis
Hi all,
I have a piston-volume setup. The fluid is a user-defined fluid using the 'user-defined-real-gas model' which restricts me to the coupled solver. I am able to compress the fluid using a prescribed wall (piston) motion.
I would like the pressures developed in the volume to influence the motion of the piston. As i understand it, the pressure force acting on the piston wall can only be calculated if the segregated solver is used (using the F_AREA command in the UDF). Is there a way i can calculate the pressure force acting on the piston wall while using the coupled solver?
Thanks in advance andy
How to read pressure at discrete points paka OpenFOAM 16 April 28, 2020 08:26
Pressure force calculation in incompressible solvers philippose OpenFOAM Running, Solving & CFD 10 December 7, 2019 05:51
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Pulsatile pressure inlet with pressure outlet a.lynchy FLUENT 3 March 23, 2012 14:45
How to get the pressure force on a surface? Jimmy Siemens 5 January 25, 2008 06:54
