Discrete Phase Data
Old   May 13, 2005, 06:44
Default Discrete Phase Data
simon
I have just been using the discrete phase particle model in FLUENT. I am having troubling getting velocity data out at set points in the domain. If I use report > discrete phase > sampling then it makes me specify a line and not a point. If I create a very small line the data given out is not just on the line but from other places in the domain as well. The data created are also very large. Is there away of me getting out the average particle velocities at set locations in the domain?
Old   May 14, 2005, 05:23
Default Re: Discrete Phase Data
abel
hello simon,
excuse me, this is not an answer, but a question i use the same model (discrete phase) for liquid fuel combustion, I do not understand the parameters shows in the "injection panel" 1- number of streams? ( = number of injector-heads?) 2- fisrt and last point ( of what?) 3-how to get velocities ( xvelo, yvelo ...)??
regards
Old   May 21, 2005, 11:25
Rhinocao
question 1:the answer is no! 2 : the position of the injection
Old   May 24, 2005, 19:16
us
Simon, What you can do is, creat a very small surface with interior boundary condition perpendicular to the spray direction. Then perform as following: 1. Go to Report-DPM 2. Open Sample trajectory panel. Select small created surfaces in Boundaries. Select appropriate injection 3.Compute. It will generate data on that perticular surface and store in .dpm file.(It would generate as many .dpm files as you created as your sampling point, if you reqd data at more than one location) 4.Open Report-DPM-Histogram 5. Read the appropriate .dpm file. 6. Select surface from the sample. Select the parameter of interest from the field box. 7. Compute/plot. This would give average value for computed parameter in your consol window and min. max values with daviation as well.
It may not be an ideal way of doing but this was the only way i found. The negative side of this method is, you necessarily should have created such small sampling surfaces with interior boudary conditions as a part of creating geometry in GAMBIT or any prepropressor you use.
Hope this helps. Best regards, -US
questions about the discrete phase model lisa FLUENT 3 January 17, 2006 08:51
Discrete Phase Model- Two Way Coupling simon FLUENT 1 June 29, 2005 18:11
Discrete Phase Model on liquid Rodrigo FLUENT 3 June 3, 2004 11:52
Discrete phase modellision through a free surface thomas Main CFD Forum 0 December 10, 2003 09:05
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
