reverse flow
Old   May 13, 2005, 06:25
Default reverse flow
P.R.Naren
How to tackle reverse flow. what is the reason for reverse flow. my outlet boundart condition is already set to pressure out (1 atm) this is concerned with gas solid two phase flow simulation
Old   May 13, 2005, 08:10
Default Re: reverse flow
Sham
change your geometry or may be consider another boundary condition.
Sham.
Old   May 13, 2005, 09:24
P.R.Naren
Sham
thanks for ur interest . But unfortunately i cant cahnge the geometry or the boundary condition. i want to simualate teh flow behavior that specified condition so what else can i do with
Old   May 13, 2005, 16:14
Sham
Having reverse flow at a pressure outlet is not necessarily bad. All that happens is that a pressure outlet becomes a pressure inlet, by using the 'reverse' quantities that you specified. Vice versa if reverse flow is recorded at a pressure inlet. So it is important to set sensible numbers for the reverse quantities (eg for the turbulence quantities, chose intensity and length scale)
Sham.
Old   May 13, 2005, 17:20
tucker
From what I've read, this is the benefit of the pressure-outlet BC. If you used outflow for example, you would not pick up reverse flow and your accuracy would suffer as a result. I agree with Sham.
Old   May 19, 2005, 02:15
shyam
Your domain size may not sufficient.Extend you domain at outlet and apply Wall-Slip-boundary condition on extended portion.
Reverse Flow Bharati FLUENT 0 September 14, 2010 02:09
Flow simulation in reverse drum mixer Patel Chirag CFX 0 July 19, 2010 16:05
reverse flow alikami FLUENT 1 June 2, 2010 05:19
Reverse flow in the VOF model yan FLUENT 1 May 26, 2005 10:14
reverse flow Giovanni FLUENT 11 October 15, 2001 04:01
