Surce Terms fluent bad results
Old   May 11, 2005, 06:54
Default Surce Terms fluent bad results
Mihai
Hy, everyone! Please tell me where i'm rong:
I have a cylinder 20 m lenght, diameter 3.7 m (volume V = 215.04 m3) i have valls (lateral), inlet and outlet. mass flow inlet m = 20 kg/s water liquid temperature 20 C (T1 = 298 K) i want to have a outflow temperature of 90 C (T2 = 363 K) The necesary heat for that is Q = m*cp*(T2 - T1) Q = 20 kg/s * 4182 J/kgK * (363 - 298) = 5,854,800 W
Surce Terms = q = Q / V = 27226 W /m3
So after the calculation i must have at exit 363 K But i have 443 K
Can you explain this?
Thank you!
Mihai
Old   May 11, 2005, 07:51
Default Re: Surce Terms fluent bad results
rom
Maybe your problem setup is incorrect. i did a short calculation for your pipe with a 50k cell mesh and your bc. fluent calculated a mass-weigthed average of 364K at the exit. looks ok by me.
rom
Old   May 11, 2005, 08:36
Mihai
thanks for your answer! It is like you said! I found the mistake. It was under my nose. ) Mihai
Comparison of fluent and CFX for turbomachinery Far CFX 52 December 26, 2014 19:11
CFX or Fluent for Turbo machinery ? Far FLUENT 3 May 27, 2011 04:02
Exporting Fluent results as 4D images in an interactive window Luca95314 ANSYS 0 October 11, 2010 18:16
UDF Source terms not producing expected results... Emmanuel Resch FLUENT 0 July 31, 2008 15:55
Exporting temperature results fro fluent to Ansys vinay kulkarni FLUENT 1 February 21, 2007 04:31
