Did somebody manage to import a "dxf" file in CDF-GEOM. I tried several times but everything I get is just a bunch of chaotic points. Shall I try another Autocad output file? Thanks! Lari |
Try importing all lines and points, which is one of the options
I think you should export from autocad using an ACIS file and then import this acis file from a cfd-geom program
wmake compiling new solver | mksca | OpenFOAM Programming & Development | 14 | June 22, 2018 06:29 |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 16:02 |
paraview installation woes | vex | OpenFOAM Installation | 15 | January 30, 2011 07:11 |
Version 15 on Mac OS X | gschaider | OpenFOAM Installation | 113 | December 2, 2009 10:23 |
PHI file structure | Eugene | Phoenics | 9 | November 2, 2001 22:00 |
