May 5, 2005, 09:57 |
vaporization and Material removal
Hai fluent users
can any one give idea for my laser cutting problem. wheather it is possible to remove the material(vaporization) by applying heat. Actually beyond certain temperature all the materials will start to vaporize.Can this vaporization be modelled in fluent. Thanks in advance M.Sundar |
May 7, 2005, 22:24 |
Re: vaporization and Material removal
As far as I know, vaporization can be simulated by Fluent, using UDF.
May 10, 2005, 00:55 |
I have a friend working on a similar problem. Laser is a high speed process and hence shock waves can be generated and the schemes available in fluent might dissipate the shock.The best way to solve the problem is using SCM. The best would be ENO schemes with relaxations.
-H |
May 10, 2005, 02:10 |
Dear Harish
Can you please explain how to deal this problem, or can you give yours friends e-mail. thank you |
Vaporization Phase? | Jason | FLUENT | 0 | March 4, 2007 23:01 |
True-VOF vs. False-VOF | edi ghirardi | FLUENT | 7 | May 24, 2005 03:10 |
