water rising behind the domain
Old   May 4, 2005, 05:41
Default water rising behind the domain
sulfi
hi all,
i am using VOF to model the flow past a body in 3D. after some time steps i found the water behind the domain rising and i am not able to get the stable solution even after 2.5 seconds(4days running time)
i found the same problem while simulating the 2D problem also.
what is the reason
how much we can rely on fluents VOF code
thanks all
Old   May 4, 2005, 06:06
Default Re: water rising behind the domain
edi ghirardi
Rising? What about the gravity components? Stable? if you mean a still free surface and you have only viscous damping you have to wait minutes...(weeks running time), but it depends obviously on the problem.
Fluent VOF model seems to be reliable such as most of others CFD codes, but maybe there's something better around (Flow 3d?). I'm asking the same question...
Good luck.
Edi.
Old   May 4, 2005, 07:33
sulfi
rising that is water volume is increasing. i am giving an inflow and outflow BC for air and water. but free surface behind the body is coming up.
Old   May 4, 2005, 13:16
edi ghirardi
Uhmm...maybe you should use a pressure condition at the outlet. Often outflow conditions lead up to have problems. Or you can place the outflow condition (if needed) as far from the main flow region as possible.
Hope this helps.
Edi.
calculation of additional variable in multiple domain cosine CFX 12 April 24, 2016 13:51
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
error using combination of step function xujjun CFX 1 January 15, 2008 17:46
Hot gas bubble collapse in cool water William Palm FLUENT 1 April 20, 2005 11:53
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 08:04
