Error msg on initialization
Old   May 3, 2005, 16:30
Default Error msg on initialization
Tushar
Thnx to all who go thru my problem.... My problem involves a porous media thru which wastewater flows and gets cleansed. I wrote two DEFINE_SOURCE terms for oxygen and cod removal.... DEFINE_SOURCE(oxy_source,c,t,dS,eqn) { real x[ND_ND]; real y,q; real source; C_CENTROID(x,c,t); y=x[1]; dS[eqn]=0; q=0.5*K1*C_YI(c,t,1)*980/(K2+C_YI(c,t,1)*980); source=ko*(C_oxy_eqm-C_YI(c,t,0)*980)-Y1*kqc*q; return (source); }
DEFINE_SOURCE(cod_source,c,t,dS,eqn) { real x[ND_ND]; real y,q; real source; C_CENTROID(x,c,t); y=x[1]; dS[eqn]=0; q=0.5*K1*C_YI(c,t,1)*980/(K2+C_YI(c,t,1)*980); source=-kac*(C_YI(c,t,1)*980-(K2*q/(K1-q))); return (source); }
I compiled these with a k-epsilon model in FLUENT 6.1
I had a velocity inlet and a pressure outlet condition set.The udfs run ok but give an error when I hook thems to the outlet mass fractions(which is the result i want)
the error returned is get_udf_function:function oxy_source has wrongtype:1!=5
I cant figure out whts wrong...can somebody help me.
tia Tushar.
FMG initialization query Mohsin FLUENT 6 November 2, 2016 03:02
code initialization - exclude pressure edna Siemens 0 January 29, 2008 11:56
Initialization a student Siemens 2 May 19, 2006 13:55
compressor initialization paglia FLUENT 0 February 1, 2006 16:14
INITIALIZATION & SORSCA july Siemens 1 May 31, 2002 03:55
